Creating a vegetation line
Command |
Workspace: Path |
Vegetation Line |
Design Suite: AEC > Plants Landmark: Landmark |
The Vegetation Line command creates a vegetation line around a selection of closed objects or symbols. It represents a massed collection of undefined vegetation. It can also be used to create an outline around plants or existing trees.
To create a vegetation line:
Select the closed objects or symbols that will form the basis of the vegetation line. The items should overlap.
Select the command.
The Vegetation Line dialog box opens. Select the type of vegetation line to create, and whether the original objects should be deleted or retained.
Parameter |
Description |
Standard Vegetation Line |
Creates an outline based on the outer perimeter of the selections |
Cloud Vegetation Line |
Creates a cloudlike outline based on the parameters specified |
Billow Size |
Select the size of the billows in the cloud shape |
Billow Height |
Select the cloud billow height |
Billow Variability |
Select how variable the billows should be |
Billow Type |
Select concave or convex billows |
Delete Original |
Deletes the original selection of objects when creating the vegetation line |
If desired, apply colors, textures, images, hatches, gradients and other attributes to the vegetation line with the Attributes palette. See The Attributes palette for more information on applying attributes.
The vegetation line can be assigned to a class (with the desired attributes). The original plant symbols can remain hidden by a vegetation line with a solid fill; however, the underlying vegetation can be revealed by hiding the vegetation line class.
